C50_20170429_131006_1493641403 soflo_will Quote
10/6/2017 9:01 AM
Hello I'm having problems with my shifting lever for some reason it seems sticky when I up or down shift it the lever gets sticky I changed the lever yesterday and still has the problem I'm starting to think that it is my shift shaft any suggestions from someone who has experienced this problem thank you..
C50_100_0170_1415598053 Hondas4Life3 Quote
10/8/2017 9:38 AM
Sounds like the shift return spring on the shift shaft is broken. Or the shift drum stopper spring. You need to take off the right side cover to look at it.
