2001 yz250 problem
jabudhibb
GA US
Edited Date/Time 11/12/2017 10:49am
My yz250 wont idle i have to give it gas to keep it running. .. It bogs when i give it throttle i can give it full throttle or half it dont matter it bogs. ..but when i turn off the gas and ride it, it rides perfect like a regular 250 2stroke..i put the needle clip at 2nd postion and when i turn on choke gas comes out of carburetor and it cuts off sometimes when i put it in gear and i can full throttle 1st gear and it wont even do a wheelie
pmshortt2
VA US
11/7/2017 9:31am
Definitely something with your carb...you’re probably getting too much fuel if it is bogging like that.
11/7/2017 9:36am Edited Date/Time 11/7/2017 9:45am
Gas pouring out of carb? Turn off the gas and it runs fine?
You need to look at your float. Replace the float needle & seat, then set float height to spec
mattyhamz2
So Cal, CA US
767th
11/7/2017 10:22am
Gas pouring out of carb? Turn off the gas and it runs fine? You need to look at your float. Replace the float needle & seat...
this. My 98 does the same thing. I need to mess with the float level a little bit still. Its now only between 1/4-3/4 throttle. Everywhere else it runs fine
dirtmike86
Grand Terrace, CA US
11/7/2017 11:19am
More info? Did this just start? Has it been sitting? What position was the clip at before? Were any parts replaced prior to this happening? Has the temperature changed drastically in your area?
jabudhibb
GA US
11/7/2017 11:58am
dirtmike86 wrote:
More info? Did this just start? Has it been sitting? What position was the clip at before? Were any parts replaced prior to this happening? Has...
it just started the temp is like the same it Haven't been Sitting before the clip was at the 4th spot all the way at the bottom..... and my floats dosent line up with the line to
dirtmike86
11/7/2017 12:33pm
jabudhibb wrote:
it just started the temp is like the same it Haven't been Sitting before the clip was at the 4th spot all the way at the...
Yeah like dirty points said. Adjust that float per manual specs. I can tell from that pic its letting to much fuel in the bowl. You can also take the floats off and put them in a bucket of water and see if any bubbles come out to make sure there isnt a leak in the float just for extra precaution.
11/9/2017 7:56pm
Your needle and seat may be leaking/ not sealing causing a rich condition. Unfortunately the seat is not replaceable on that carb. You could replace the needle and see how it runs but chances are the carb will need to be replaced. It also looks like your float is bent where it contacts the needle, I would replace that as well if you decide to try to get that carb working.
11/9/2017 10:09pm Edited Date/Time 11/9/2017 10:12pm
Your needle and seat may be leaking/ not sealing causing a rich condition. Unfortunately the seat is not replaceable on that carb. You could replace the...
Replace the valve and set the height and he'll be fine
11/10/2017 12:17pm
But only the needle is replaceable, the seat is pressed in and not replaceable. If the seat itself is bad the carb needs to be replaced.
11/10/2017 12:48pm Edited Date/Time 11/10/2017 12:49pm
The seat on a PWK is harder than the needle, they last a really long time. Just clean it up with a qtip and some steel wool.
I also think it's pretty clear from the pic that his float height is likely set wrong
JustMX
TN US
11/10/2017 2:51pm
The problem is simple....you can see it plain as day in the photo.....Somebody flipped your cab upside down and took the float bowl off.
lumpy790
York, SC US
11/12/2017 5:34am
Pull the head and see how much damage there is from detonation. You must use Race gas in these YZs
speed_racer
Aiea, HI US
2007th
11/12/2017 7:54am
Put some fine steel wool on the end of a q tip.
Put q tip in drill motor.
Put q tip with fine steel wool inside brass seat and spin drill, watch seat get clean and shinny.
jabudhibb
GA US
11/12/2017 10:49am
I use pump gas
Post a reply to: 2001 yz250 problem
