Shell Rotella Oil??
NESC98
Buzzards Bay, MA US
Edited Date/Time 3/24/2014 2:17pm
Ive seen some people using this one of my friends uses it in his honda.. Whats your thoughts on using it i have kawis 450 and 250..
CR500Rider
San Antonio, TX US
3/19/2013 1:41am
I use it in everything I own that requires oil.
BobbyM
AZ US
3/19/2013 1:41am
that stuff is the most refined highest quality lubricant in the world....no shit.
justme
Southern Texas, TX US
3/19/2013 2:34am Edited Date/Time 3/19/2013 4:50am
Used to use it on both sides of the Honda 450 no problems at all good stuff. Also in all my heavy equipment oil changes not as cheap as it once was but niether is anything else.
mxracer816
Atlanta, TX US
2858th
3/19/2013 3:18am
Both sides of my 07 Honda, tons of hours with no issues.
jleews6
Hardy, VA US
3/19/2013 4:17am
Me to. I have used it in all our 250 and 450s and have never had a problem. The last 450 had a ton of hours on it and everything still looked new inside when we pulled it apart.Its cheap so I change the oil every 2 hours.
My last van still ran like new and had good oil pressure and no noises at 225K when I sold it and that got fresh Rotela every 5 to 7 thousand miles.
motox55
Arlington, TN US
3/19/2013 4:35am
What weight rotella is everyone using?
Frank
WI US
3/19/2013 5:03am
15w-40
pilotdude
Vancouver, WA US
3/19/2013 5:05am Edited Date/Time 3/19/2013 5:07am
Rekluse recommends Shell Rotella T.
Edit: And if anyone knows their stuff, I figure they do.
DoctorJD
Somewhere in..., GA US
3/19/2013 5:18am
I've used it for years. Cheap and easily available.
OP, if you go to thumpertalk and search on "Rotella", I promise you, you'll have (at least) a days worth of reading.
slipdog
Nor Cal, CA US
3/19/2013 5:34am
Rotella T 15-40... Zinc is good!
mxtech1
Galesburg, IL US
3/19/2013 5:38am
Here we go again.....
One of the most beat up threads of all time. Thumpertalk has page after pager of topics just like this.
3/19/2013 5:39am
The only difference would be that the TT replies are all unfounded conjecture.
So Rotella is ok for clutches I take it. You're running the synthetic Rotella T 15w 40?
Roscoe33
London CA
3/19/2013 5:47am
X2
Rotella T takes more heat than any other oil.
slipdog
Nor Cal, CA US
3/19/2013 5:48am
The only difference would be that the TT replies are all unfounded conjecture. So Rotella is ok for clutches I take it. You're running the synthetic...
Not the synthetic, the standard T in the white jug for $11/gal at wall mart. Same with the Chevron Dello 400.
3/19/2013 5:54am
I was getting ready to say, WalMart sells the standard one, but you have to go to the Auto Parts store to get the blue jug synth.
If it's ok for wet clutches, i'll give it a shot in the two stroke. I have been running ATF, but that stuff eats plastic (water pump gear)
slipdog
Nor Cal, CA US
3/19/2013 6:05am
It's ok for wet clutches because its a Diesel blended oil, so it doesn't have the friction modifiers required for Passenger car oil that are bad for the clutch.
MX558
3/19/2013 6:27am
I've used it in all my mx bikes as well. I also used it back when I was RR in all my R6's with their slipper clutches and no issues at all. Shifts like butter.
yota
Crystal River, FL US
3/19/2013 6:34am
I use straight 40 wt Rotella in all my gearboxes (all 2 strokes). bought a 5 gal bucket at a truck shop, lasts forever.
CamP
Colleyville, TX US
3/19/2013 6:40am
I've used it for years in my CRF tranny's, with no problems. What's odd is that when I use it in both my 2-stroke tranny's, I get some clutch slippage under heavy use. When I swapped it out with some Motorex gear oil, the slipping disappeared. I don't abuse the clutch with the thumpers like I do with the 2-strokes, so that may be the difference.
Highsider
Way Toasty, IA US
3/19/2013 6:40am Edited Date/Time 3/19/2013 6:42am
Who the hell reads Thumpertalk? :-)
4stroke4DWIN
texas city, TX US
3/19/2013 6:49am
Rotella T 15-40 in everything I own, I even use it in the service area of my shop. Good stuff and no problems.
chillrich
Kamloops CA
3/19/2013 7:22am
slipdog wrote:
It's ok for wet clutches because its a Diesel blended oil, so it doesn't have the friction modifiers required for Passenger car oil that are bad...
Rotella T is formulated for wet clutch. 175 + Vet hours on 2 different YZ250Fs, no issues. Was pleased to see Rekluse developed their clutches using this product. Have heard that Yamalube is the same product, different bottle.
Chili
Winnipeg CA
3/19/2013 7:46am
We've used the 15-40 in every 4 stroke we've owned including our last 3 Kawi's. I use the T6 5-40 in my Street bike.
dirthead1
Southern, CA US
3/19/2013 8:53am
I've used both versions of the Rotella in my four stroke bikes for years without incident.
I hope people realize that most oils labeled as "synthetic" are not 100% synthetic having only small percentage of true synthetic oil .
3/19/2013 9:02am
CamP wrote:
I've used it for years in my CRF tranny's, with no problems. What's odd is that when I use it in both my 2-stroke tranny's, I...
I'll probably pass on it then. I cornhole the clutch on my CR.
Bytor
Colorado Springs, CO US
3/19/2013 9:06am
I did the math and it was cheaper to use Motul 300V because everyone says to change the rottella every ride or 2 hours. I can go 12-15 hours depending on the weather. Also I don't like the idea of pulling drain plugs all that much I know a few guys that have ha to fix there drain plug threads from all those oil changes.
CR500Rider
San Antonio, TX US
3/19/2013 9:21am
I do not have this problem on ANY of my CRs.
CamP
Colleyville, TX US
3/19/2013 9:34am Edited Date/Time 3/19/2013 9:38am
Do you fan the clutch on your CR500? I don't fan the clutch on my CRF450 and I've never had it slip with Rotella. I do fan the clutch on my CR and RM 250's, and that's when I experienced clutch slippage with Rotella. Like I said before, that disappeared when I switched to Motorex gearbox oil. I still run rotella in the 450.
Post a reply to: Shell Rotella Oil??
