4/9/2014 7:07am
Hello everyone,
I have a 2009 YZ250f with about 75-100 hours on it. The engine is complete original and stock. It runs great and starts 1st or 2nd kick every time. I change my oil ever 3-5 hours and properly clean and oil my air filter each and every ride. I am very meticulous with my maintenance.
But anyway, I believe it's time for a rebuild now. I was wondering what you guys think would be best to do to it? Just freshen up the top end and check valve clearance? Or freshen up the top end+valve clearance and and also rebuild the crank?
And also, what brand would be the best parts to use? I've heard Wiseco is no good.
Thanks for your input
Checking the valves should be part of your 5 hour maintenance. You should know where you are at shim wise and the state your seats are in just based off of that. You should still disassemble and check for wear while you have it apart.
Do not ever use a wiseco crank, but the pistons are OK. I would still stick with ProX or OEM for the pistons.
For the crank, OEM is the way to go. Either buy the complete crank (will run you about $330), or the rod, bearing, and pin (will run you about $140) and rebuild it. If you do get it rebuilt it is a good idea to get it balanced. A rebuild+balance (with the pin welded where the crank is true) on it will cost you about $200 plus shipping if you send it off, so maybe 390 for a rebuilt crank.
You could also get a pro-x rod kit rather than buying the OEM parts. Pretty much the same and it will only be about $100 instead of $140, and will have the little end bearing too.
3-5 hrs fresh Rotella T, clean stainless steel oil filter every 2nd oil change
~25 hrs check valve clearance, usually require shimming at ~50 hrs
~50 hrs replace piston and cam chain
At 125 hrs I replaced valves, seals and springs. Guides and sets were in good shape.
Had a piston failure at 165 hrs, expansion ring came loose and went into crankcase. Split the cases and replaced a few bearings and cleaned everything. While it was apart I had the crank pressed apart and inspected, everything was nice and tight, no signs of excessive wear so I had them press it back together and true it etc. I will check it in another 50 hrs when I do my next topend and see how it feels. If she gets loose I'm going to add a stroker to the 290 :-) If the prices were the same as quoted above up here in Canuckia I would have replaced the rod when it was apart.
(On a Honda...)
Stainless steel valves are very durable but the increased weight makes it necessary to use heavier springs, these increased weights and forces of valves and springs can increase wear on the valve seats.
*Sent the crank out for rebuild. That was about $175.
*All new bearings. You need a blind puller, oven, press to pull/install new bearings. If you are going to split the cases...REPLACE THE BEARINGS!
*Replaced all circlips and washers in the tranny
*All new seals
*New clutch plates and discs
*All new O-rings
*All new gaskets
*New cam chain
*New Piston, Rings, Pin, Clips (CP CP CP CP!)
*If the cylinder is out of spec...get it re lined. I have found that ever 3-4 upper ends...the cylinder needs to be re-plated
Tools you need:
*Blind bearing puller
*Press
*Feel gauges
*Mics through 4"
*Bore Gauge (resolution to .0001")
*Dial indicator and VBlocks
*Torque wrenches
2. Attach "monster energy" stickers to shrouds.
Post a reply to: YZ250F rebuild advice, what does it need?
