C50 rssmotorx Quote
10/2/2017 12:54 PM
hi all, I have a 2017 crf 450r and I'm having a bit a drama setting the suspension up,
I'm 15 stone and a fairly aggressive rider, so I've upgraded the springs to the next set up, the problem I'm having is setting the end part of the damping up,.......if I land to flat it easily bottoms out, and im not sure how to tune sus in to take heavy-ish landings, any help is greatfully received, thanks jays
C50_jessy1_1471467436 CarlinoJoeVideo Quote
10/2/2017 1:08 PM
Here's a podcast from Kris Keefer that has great info about that bike:
Show #2 Living with the 2017 Honda CRF450
https://itunes.apple.com/us/podcast/show-2-living-with-the-2017-crf450/id1245516386?i=1000386765112&mt=2
C50 rssmotorx Quote
10/2/2017 1:12 PM
I don't have an iTunes account bud, I have a Samsung
C50 rssmotorx Quote
10/2/2017 3:09 PM
any one else help
C50_trey_c_1439133231 NeedMoto Quote
10/2/2017 4:21 PM
At close to 210 pounds, and aggressive riding the front is valved a bit light for you. Add a bit more oil, and the fact you've already changed spring rates, you just need a stiffer valved front end. The more you go in on compression, the harsher it will get with the current valving, you'll still blow through it.
With my re-valve and 1 higher spring rate, my 17 is the funnest, balanced bike I've had to date.
Good luck to you in dialing in your ride
10/2/2017 4:27 PM
rssmotorx wrote:
I don't have an iTunes ...more
I didn't know you can only access iTunes from an iphone or mac computer?
C50_img_0447_1492142509 Bennett59 Quote
10/2/2017 9:47 PM
I weigh 208 and had my stuff done by Factory Connection and they left the front springs stock and just did valving change and stiffened up rear shock. Night and day difference, stock coming into the corners the front end just felt like it would just sink down and throw me all off balance. Also has good bottoming as couple of my local track has some good rollers to flat.
Thank you,
Fly Racing, WPS, Dt-1, Mika Metals, Maxima, EKS Googles
See All Deals ยป
DEALS
