How do I remove this bearing?
z71will
Pinson, AL US
Edited Date/Time 10/12/2017 9:37pm
There's no way to hit or press it out from the back like I usually do. So how am I supposed to get it out?
Acidreamer
Mansfield, OH US
10/10/2017 12:25pm Edited Date/Time 10/10/2017 12:27pm
Youll want to get a bearing puller set and a torch. Heat up the case and utilize the puller and it will pop right out. You might be lucky enough to heat the backside and tap it with a deadblow to get it to fall out. Heat the aluminum to 220 degrees for best results. A good test is to heat it and drip a drop of water on it. If it evaporates instantly its hot enough. Dont go too much hotter or you will warp shit
526
Colgate, WI US
10/10/2017 1:07pm
Yep warm the case and it will fall out
z71will
Pinson, AL US
10/10/2017 1:58pm
karlz wrote:
Heat the casing up and the tool you need is called a blind bearing puller.
www.karlzracing.com
That link just took me to the home page
karlz
10/10/2017 2:37pm
That link is my signature not a link to the tool. You can buy the tool on ebay or motor accessory store.
www.karlzracing.com
omalley
Snohomish, WA US
10/10/2017 3:18pm
If you don’t want to buy a puller set, autozone has them on their tool rental program (you buy the set, then get refunded when you return it). Just used one for my CR’s rebuild.
ktm-5
Ravenna, MI US
10/10/2017 3:25pm
Put the case in the oven 15 minutes at 300deg and it will fall out
Jake_CR250R
Ozark, MO US
10/11/2017 8:56pm
If heat doesn't work and you can't get your hands on a bearing puller, try the grease packed rag method.
garagedog
Tulare, CA US
722nd
10/11/2017 9:02pm
The what method? Please explain...
seth505
SD, CA US
1271st
10/12/2017 11:04am
Get one - https://www.rockymountainatvmc.com/p/989/20342/Tusk-Bearing-Remover It's the right tool for the job. You may not use it all the time, but when you do youll be glad...
It's the right tool for the job. You may not use it all the time, but when you do youll be glad you have it.
Yes!
I have that exact set and it is great.
FGR01
AZ US
1327th
10/12/2017 8:57pm
Notice in this video it is a shielded bearing. That retains the grease pressure behind the bearing. The bearing in the motorcycle cases is fully open. You might get lucky if you pack enough rags in there but most of the grease would probably just push through the bearing. Anyone ever done it successfully on an open bearing like this?
Jake_CR250R
Ozark, MO US
10/12/2017 9:37pm
FGR01 wrote:
Notice in this video it is a shielded bearing. That retains the grease pressure behind the bearing. The bearing in the motorcycle cases is fully open...
That is probably what would happen. Still might be worth a shot if he's waiting for a puller to be shipped. Worst case you make a greasy mess
Matt Fisher
Visalia, CA US
1177th
10/13/2017 9:27am
seth505 wrote:
Yes!
Harbor Freight has those for $69
With really small bearings that are too small for the tool to fit in, pull the bearing retainer out of the way, push all the bearings to one side and pull out the inner race. The remaining outer race can be removed with the slide puller.
mattman631
Mcalester, OK US
10/16/2017 8:00am
Do it right and buy this...takes 30 seconds to pull bearings
Post a reply to: How do I remove this bearing?
