C50 dombrowsky106 Quote
10/4/2017 4:12 PM
I love my new yzf and has amazing bottom and mid but I like to get more top end.without splitting my case I will eventually do that when it needs refreshing lol. But I thought a pipe might give it sum? But I've read that the stock exaust is the best but if sum one thinks differently and knows a good pipe I was thinking pro circuit slip on but also heard they have zero bottom end and I like my bottom end. Also has anyone had any luck with dropping a tooth in the back .a lot of questions but just curious
C50_img_20151127_132255925_1450107346 mxb2 Quote
10/4/2017 4:57 PM
Gearing , exhaust ,mapping all can help. Get a gytr tuner . Great option for that bike.
C50_ea756c05_b914_4029_8429_0ca1b5b26456_1513024990 Shannon ward Quote
10/4/2017 7:03 PM
I dropped 1 tooth in the rear and went with a full fmf made a pretty big difference imo although it may have took just a tad of the initial bottom hit away the mid seems to pull harder and top pulls longer for sure. My next thing is gonna be a vortex ignition I have a tuner but seems to me the stock mapping is the best but I haven’t actually gotten the hang of the tuner yet.
C50_jessy1_1471467436 CarlinoJoeVideo Quote
10/4/2017 11:24 PM
I think with mapping you can make a different on the top. The GYTR tuner is pretty cool.
C50 Acidreamer Quote
10/5/2017 6:21 AM
I believe the hotcams (stage 2?) add top end. A high comp piston will give you more power everywhere too. Im assuming you want more power in the higher rpm range, not more top speed..
2009 Kawasaki KX450F
2002 Suzuki GSXR 600
10/5/2017 2:44 PM
Shannon ward wrote:
I dropped 1 tooth in the ...more
That's what I was thinking and prob what I'll do. But It would be cheaper for me to do the tuner. Let me know if you mess with it and what your thoughts are cause if I could get good results with that that would be great
C50_89326580_1269555170 NITRODOG Quote
10/5/2017 3:44 PM
1st thing we did on our 2015 250's was to put the 450 air intake boot on...not sure if the 17's are the same or not though....stock pipe is pretty good and you can do a lot with the GYTR tuner...a good hop up shop should have a good map for it.
also...VP MXR02 hold her wide and let her eat!
10/8/2017 6:06 PM
I'm thinking I'm prob gonna with a full pro circuit system and map it. But I've heard the pc exhaust have no bottom to them at all has anyone ever ran pc on a newer yz250f and liked it
10/8/2017 7:31 PM
dombrowsky106 wrote:
I'm thinking I'm prob ...more
PC is for mid, top end. Fmf. Better low, mid. I wd def check into Dr d exhaust. Great Yamaha stuff,alot of. R@d .
C50_screenshot_2017_01_02_16_15_37_1491551658 ktm-5 Quote
10/8/2017 8:46 PM
I've been told the best fuel for a 250f is vp pro6
10/8/2017 9:46 PM
ktm-5 wrote:
I've been told the best ...more
X2 with a remap, or ignition. Mr12, renegade sx4,4+ also.
10/8/2017 11:58 PM
mxb2 wrote:
X2 with a remap, or ...more
On my 16 250sxf the stock aggressive map worked great with the pro6, if I remember it was a gain of 2hp. I had Tokyo mods do a remap for vp4.4 but the pro6 worked better on the stock map and the Tokyo mod map worked better with 4gal non-enthanol + 1gal vp110 per dyno anyways
See All Deals »
DEALS
