Trouble Replacing Throttle Cable on 2013 Crf450r
Getting to the throttle body and taking the cables out was fairly easy. When I put the new one back in, the throttle now barely moves at all. I've tried numerous things to make it work, but I've had zero success. Anyone out there have any tips on what I should try next?
GaryC1
Belfast GB
7/7/2017 2:08am
Getting to the throttle body and taking the cables out was fairly easy. When I put the new one back in, the throttle now barely moves...
Have you routed the cable the exact same way as it came out? Also compare the adjustment at both ends of the cable to make sure it is set the same as the old cable and finally make sure it is guided correctly on the throttle body and isn't snagged or caught.
All obvious things I have mentioned so sorry if you have checked them but other than that I can't think of anything. Many be worth re-fitting your old cable to see if that works again and it could be an issue with the new cable.
Good luck
7/7/2017 2:52am
GaryC1 wrote:
Have you routed the cable the exact same way as it came out? Also compare the adjustment at both ends of the cable to make sure...
Good luck
Thank you for the reply! Unfortunately I have tried all of those things. I routed it the exact way I took it out too. But I'll try and take it out and then hook it all back up, crossing my fingers it works because this has been one of the most annoying this I've dealt with lol.
GaryC1
Belfast GB
7/7/2017 5:12am
Yeah it's a weird one for sure! Does the throttle flap move ok when you move it by hand? And also when you say the throttle barely moves do you mean the actual grip moves very little then jams or stops? If you were able to throw up a couple pictures of the throttle body area then that would be helpful too! I have had some issues before that were solved by some embarassingly simple solutions haha
7/7/2017 1:55pm
GaryC1 wrote:
Yeah it's a weird one for sure! Does the throttle flap move ok when you move it by hand? And also when you say the throttle...
When the cables aren't attached to the throttle, they move freely and smoothly, but once I put the cables into the throttle housing, it's stiff as hell when I turn the throttle. I've tried three different throttle tubes and have had the same result. I plan on working on it extensively this coming Monday. If I can't get it to work I'll snap some pics and post them.
Falcon
Menifee, CA US
798th
7/7/2017 3:02pm Edited Date/Time 7/7/2017 3:52pm
Make sure your cables aren't cross-referenced. You have a push-pull cable system and they definitely need to be attached to correct side of your throttle body.
If your throttle won't open at all, this may be the issue.
7/7/2017 4:42pm
Falcon wrote:
Make sure your cables aren't cross-referenced. You have a push-pull cable system and they definitely need to be attached to correct side of your throttle body...
To be completely honest, that never even entered my mind. If I did that I'm gonna feel like such a dummy haha. Thank you for the advice! I'll definitely be checking it.
NeedMoto
Lincoln, CA US
7/7/2017 11:06pm
Cables cross referenced will be your issue as Falcon mentions^^^
Good luck with fixWink
7/11/2017 3:59pm
Falcon you were absolutely spot on. I feel pretty silly having screwed up a simple task. But thank you for the info.
Post a reply to: Trouble Replacing Throttle Cable on 2013 Crf450r
