Yz250 coolant leak
jabudhibb
GA US
Edited Date/Time 12/20/2017 11:05pm
My 01 yz250 drips coolant when I pour it in and I start kicking it and when I get it started it like pours out but idk we're .. what can be causing this
Acidreamer
Mansfield, OH US
12/12/2017 3:35pm
Cause is a gasket not sealing. Youll have to find it and check it out for more info.
Paw Paw 271
Benton, LA US
12/12/2017 8:51pm
Check to see if the coolant is coming out a small hole under the water pump on the engine side cover. If so then your water pump needs a rebuild. Also check your radiator cap as it may be worn out.
dirtmike86
Grand Terrace, CA US
12/13/2017 9:31am
Check to see if the coolant is coming out a small hole under the water pump on the engine side cover. If so then your water...
I thought the weep holes were only on 4 strokes?
lumpy790
York, SC US
12/13/2017 8:29pm
I believe they all have a weep hole
12/14/2017 3:08am
They do. Usually when the inner gasket fails.
Rebuild kits are somewhat cheap.
tobias56
Hinesville, GA US
12/20/2017 11:05pm
We will be working on a YZ250 right after we finished installing the new tires, forged wheels and the brake job on the current truck project. A rebuild kit seems a better option for this bike.
Post a reply to: Yz250 coolant leak
