Massive garage / parts hoard cleanout
WileCyot
Katy, TX US
Edited Date/Time 5/11/2016 11:04pm
Hey guys,
My game room has been my parts storage area for some tideas now and it's crowded. I'm going to be losing parts below and if you need anything let me know. I'll ship all over the US and possibly internationally.
Contact mw here or via cell
832 - five tree ate - 8()()9
I know it's a pain but it prevents fishing.
2006 YZ450F
-Front Caliper and Line
-Rear Brale Caliper and Line
-Right Crank Case Cover
-Kick Lever
-CDI, harness, and Coil
2008 CRF450R
-Magura Clutch 0120528
2006 CRF250R
-OEM Seat
2004 CRF250R
-OEM seat
-Head (needs 1 valve guide replaced and new valve)
-Cam
-CDI box, Harness, and Coilpack
-Right Radiator
-Left Radiator
-Cylinder
-Full OEM Exhaust
-Rear Shock
-Swingarm
-Frame (Bill of Sale)
-Rear Brake Assy (caliper, line, and master)
-Pegs
-Carb
02 cr125r
-seat
-transmission
-crank
-right crankcase cover
-clutch cover
-reed cage Assyria
-stator cover
-power valve ball governor
-damaged cylinder (needs replating)
-coil
-Kickstart gear assy
2001 CR250R
-Cylinder KZ3V
-Cylinder Head KZ3P E-2
-Power Valve Assy
-OEM Reed Cage
-Left Crank Case
-Transmission
-Crank
-Ignition Cover
-Powervalve Ball Governer
1999 CR250R
-forks
-seat
-rear suffrage
-airbox and boot
-OEM Expansion Chamber with Aluminum Guard
-FMF Gnarly
-Swingarm
-Rear Shock
-Triple Clamps
-Front Brake assy (Caliper, Line, Master)
-Rear Brake Caliper and Assy
1998 CR250
-Forks
-seat
2004 RM125
-Forks
-Swing arm
-Right Radiator
-Front Brake Caliper
-Front Master Cylinder
-Head (will need cleaned up)
-Cylinder (will need cleaned up)
-Complete bottom end (will part out as crank is shot)
-oem expansion chamber (dents n dings not terrible)
2004-06 KX250F & RMZ250
-Fluidyne Radiator set
-crank cases
-clutch assy (inner & outer baskets with pressure plate and discs)
-Trans
-stator & flywheel
-Kickstart Assyria
suzook241
PA US
2/8/2016 9:31am
Are you able to PM me prices and or pictures of the 04 RM forks, swing arm and head?
WileCyot
Katy, TX US
2/8/2016 4:30pm
I sent pics. You never responded. I'll assume you're not interested.
2/8/2016 8:02pm
What would you want for the 04 rm 125 transmission, The primary case cover and water pump cover (not including clutch cover) and the swing arm?
WileCyot
Katy, TX US
2/8/2016 8:13pm
By primary case cover I assume you are referencing the right crank case cover? The large cover that the clutch cover attaches to?
Pricing:
Trans - $100
Right Crank Case Cover - $40
Water Pump Cover - $10
Swingarm - $50
These prices are picked up in Houston. Shipping will add cost as you can imagine.
WileCyot
Katy, TX US
2/8/2016 8:34pm
How much for the yz front brake?
Caliper only? Master only? Caliper line and master?
Debe
IT
2/9/2016 2:06pm
How much for the Honda Cr 125 2002?
you can send me some pictures?
WileCyot
Katy, TX US
2/9/2016 2:18pm
What do you need from it?
MxKing809
Big Sand Whoops, MI US
334th
2/9/2016 5:39pm
What's this? And do you have a silencer for it?
WileCyot
Katy, TX US
2/9/2016 5:43pm
You said you wanted to see the CR.... It's in a box in pieces man. Let me know what parts you want and I'll get you pics.
MxKing809
334th
2/9/2016 6:35pm
Lol, that was the other guy asking about the entire bike. I'm after a PC silencer and want to know what reeds you have. What's "reed cage Assyria"?
Cmiller493
Hays, KS US
2/9/2016 7:59pm
Do you by chance have the carb off the 99 cr250 or the showa forks off the hondas?
WileCyot
Katy, TX US
2/9/2016 8:15pm
I do but it's being used on my 01.
Which showa forks are you looking for?
Cmiller493
Hays, KS US
2/9/2016 8:40pm
Dual chamber 02+ cr/crf i think I replied to another post of yours so sorry for the double posting lol
WileCyot
Katy, TX US
2/9/2016 8:50pm
The forks from the 04 crf250r are actually on an 01 CR250R of my buddy's.
Debegio
IT
2/10/2016 6:12am
Sorry, the seat, thx
2/10/2016 9:53am
WileCyot wrote:
Hey guys, My game room has been my parts storage area for some tideas now and it's crowded. I'm going to be losing parts below and...
Hey guys,
2006 YZ450F
-Kick Lever
2008 CRF450R
2006 CRF250R
-OEM Seat
2004 CRF250R
-OEM seat
-Cam
-Right Radiator
-Left Radiator
-Cylinder
-Full OEM Exhaust
-Rear Shock
-Swingarm
-Pegs
-Carb
02 cr125r
-seat
-transmission
-crank
-clutch cover
-reed cage Assyria
-stator cover
-coil
2001 CR250R
-Cylinder KZ3V
-Power Valve Assy
-OEM Reed Cage
-Left Crank Case
-Transmission
-Crank
-Ignition Cover
1999 CR250R
-forks
-seat
-rear suffrage
-airbox and boot
-FMF Gnarly
-Swingarm
-Rear Shock
-Triple Clamps
1998 CR250
-Forks
-seat
2004 RM125
-Forks
-Swing arm
-Right Radiator
-crank cases
-Trans
-stator & flywheel
-Kickstart Assyria
Hey do you still have a 2004-2008 rm125 motor .
WileCyot
Katy, TX US
2/10/2016 9:56am
Hey guys,
2006 YZ450F
-Kick Lever
2008 CRF450R
2006 CRF250R
-OEM Seat
2004 CRF250R
-OEM seat
-Cam
-Right Radiator
-Left Radiator
-Cylinder
-Full OEM Exhaust
-Rear Shock
-Swingarm
-Pegs
-Carb
02 cr125r
-seat
-transmission
-crank
-clutch cover
-reed cage Assyria
-stator cover
-coil
2001 CR250R
-Cylinder KZ3V
-Power Valve Assy
-OEM Reed Cage
-Left Crank Case
-Transmission
-Crank
-Ignition Cover
1999 CR250R
-forks
-seat
-rear suffrage
-airbox and boot
-FMF Gnarly
-Swingarm
-Rear Shock
-Triple Clamps
1998 CR250
-Forks
-seat
2004 RM125
-Forks
-Swing arm
-Right Radiator
-crank cases
-Trans
-stator & flywheel
-Kickstart Assyria
Yes but it needs a new crank and cylinder work. I was going to part it out entirely.
2/10/2016 10:06am
Hey guys,
2006 YZ450F
-Kick Lever
2008 CRF450R
2006 CRF250R
-OEM Seat
2004 CRF250R
-OEM seat
-Cam
-Right Radiator
-Left Radiator
-Cylinder
-Full OEM Exhaust
-Rear Shock
-Swingarm
-Pegs
-Carb
02 cr125r
-seat
-transmission
-crank
-clutch cover
-reed cage Assyria
-stator cover
-coil
2001 CR250R
-Cylinder KZ3V
-Power Valve Assy
-OEM Reed Cage
-Left Crank Case
-Transmission
-Crank
-Ignition Cover
1999 CR250R
-forks
-seat
-rear suffrage
-airbox and boot
-FMF Gnarly
-Swingarm
-Rear Shock
-Triple Clamps
1998 CR250
-Forks
-seat
2004 RM125
-Forks
-Swing arm
-Right Radiator
-crank cases
-Trans
-stator & flywheel
-Kickstart Assyria
What's your cell number I'll Tex you pics of what my motor did and can you send me some of yours please thanks jess
WileCyot
Katy, TX US
2/10/2016 10:11am
It's at the top.
MxKing809
334th
2/10/2016 11:55am
MxKing809 wrote:
Lol, that was the other guy asking about the entire bike. I'm after a PC silencer and want to know what reeds you have. What's "reed...
So do you have a cr125 silencer and what kind of reed cage is that?
WileCyot
Katy, TX US
2/10/2016 12:08pm
Stock reed cage and stock silencer.
2/10/2016 12:53pm
WileCyot wrote:
It's at the top.
Ok I sent you a Tex
Jim in VA
Louisville, KY US
3/4/2016 9:49pm
She said send pics of yours, she'll send pics of hers. Woohoo
WileCyot
Katy, TX US
3/5/2016 5:11am Edited Date/Time 3/5/2016 5:11am
If the Rm 125 engine is still available email me a price and some pics to skyracing@comcast.net
The engine is torn down in a box currently. What parts do you need?
4/27/2016 5:34pm
What is missing from the cr125 engine? And how much for all the engine parts?
Post a reply to: Massive garage / parts hoard cleanout
