I know this might sound a little crazy but what about vapopr blasting an assembled engine? If everything is sealed up properly would there be a chance of media passing through the gasket? I was thinking about sealing up the oil seals with the shafts and everything and putting a rubber plug on the exhaust with a dummy carb on the intake side that would completely seal the intake. I have access to a blasting unit and can't come close with any process to what vapor blasting can do...
Post a reply to: Vapor blasting a whole engine
