2014 Kx 250 Two Stroke Plastic Conversion
Bressler11
Lock Haven, PA US
Edited Date/Time 6/15/2018 9:56pm
There were a couple of things he did that I didn't agree with and I would have done differently but it turned out nice
https://www.youtube.com/watch?v=Fjrp0oFZELw
bish153
Frisco, TX US
12/21/2014 6:59pm
The gaps between the tank and shrouds would drive me ape shit
Bressler11
Lock Haven, PA US
12/21/2014 7:14pm
Yes GE217 built one where he used the 2012-2015 tank and everything mounted up
ge217
Vero Beach, FL US
12/25/2014 5:19am
that guy built his off of mine. since i didn't release any pics showing how i mourned the air boot and the 4t subframe he had to guess which is a little different than mine as i use the 4t boot with 4t air filter. he used 2t air boot .he used the stock 2t tank, and stock 2t seat bc you can't use a 2t tank with 4t seat or vis versa . if he would have used the 4t tank he wouldn't of had to move his seat mounts.. if your going to do it, my way is the fastest and easiest. Also a lot of people have no clue on what you do with the hole from the fuel pump in the 4t tank. I can also take at the 4t stuff off and bolt the 2t stuff right back up.
Markee
Suffolk, VA US
1890th
12/25/2014 5:30am
Looks great
OriolMassot
We speak Catalan AD
12/25/2014 5:36am
Well... If you take a look from the distance, yeah, looks nice. When you close up to get better views, things change drastically. Sorry mate, but I would never do that on my bike. I'd rather prefer to keep it as it was in 2006. Although, the pics ge217 released look much better.
I think, if UFO would be wiser, they could not only release an updated set of plastics for the YZ's but also for the KX's, RM's and CR's.
Just sayin'.
pCp 252
Hampden, MA US
2530th
12/25/2014 10:24am
I'd like to know what you did with the hole from the fuel pump. I have a 13' KX250F tank I want to put on my 2010 carbureted KX250F. Somehow I need to put a petcock on the '13 tank. I thought of using a piece of aluminum stock cut to size, but what did you do?
philG
12/25/2014 3:38pm
make a template , and get it water jet cut.
ge217
Vero Beach, FL US
12/25/2014 4:33pm
pCp 252 wrote:
I'd like to know what you did with the hole from the fuel pump. I have a 13' KX250F tank I want to put on my...
what philg said would work. or if you able able to so it yourself more power to you. all you have to do is make a plate and then mount a petcock to. Hint watch out for the cylinder head frame mount when finding the proper location of the petcock. To mount the plate to the tank you can use the stock fuel pump bolts and the rubber o-ring so your plate will seal.
ge217
Vero Beach, FL US
12/25/2014 4:35pm
Well... If you take a look from the distance, yeah, looks nice. When you close up to get better views, things change drastically. Sorry mate, but...
Just sayin'.
it was really easy. Probably took 45 min to convert everything. the silencer even bolts right up to the 4t exhaust mount. like it was meant to be..
12/30/2015 5:01pm
Just sayin'.
ge217 wrote:
it was really easy. Probably took 45 min to convert everything. the silencer even bolts right up to the 4t exhaust mount. like it was meant...
ge217- what sub frame did you use mate
mx836
; BF
12/30/2015 6:39pm
Just sayin'.
Did you do a build thread? Would be really interested in knowing more.
cmotodad
Yorba Linda, CA US
12/30/2015 9:51pm
If you look at the new sub frame mount on the chain side, you can see it is longer. Looks to me like it is a 4stroke subframe, seat, tank, shrouds and side panels. I am doing my 05 250f/500 the same way.
ge217
Vero Beach, FL US
12/31/2015 9:17am
Just sayin'.
4T. I can still bolts all the stock stuff right back up as well.
ge217
Vero Beach, FL US
12/31/2015 9:18am
Just sayin'.
I did not do a build thread. When I built it I didn't want anyone to know how I did it.
ge217
Vero Beach, FL US
12/31/2015 9:21am
cmotodad wrote:
If you look at the new sub frame mount on the chain side, you can see it is longer. Looks to me like it is a...
Im looking to sell my kit if you know anyone who may be interested in it. Seat,Tank,Subframe, Airbox.
ATKpilot99
Lake Geneva, WI US
12/31/2015 9:42am
Nice work for sure but original with updated front fender works too.
BigDaddyG
Saint Helens, OR US
12/31/2015 10:31am
ATKpilot99 wrote:
[img]http://www.2wheeltuesday.com/wp-content/uploads/2009/01/2stroke_kawasaki.jpg[/img] Nice work for sure but original with updated front fender works too.
ge217 did a nice job, that's for sure. But this RV bike is 2nd to none.....so bad ass!!!!
12/31/2015 5:38pm
Ge217 I'd be keen but in in Australia
ge217
Vero Beach, FL US
1/11/2016 10:48am
sent pm's to both steeeeeeeeve and Jeff_Gogel
bvm111
Las Vegas, NV US
1/11/2016 11:02am Edited Date/Time 1/11/2016 11:02am
I would be interested in the Kit suspension and triple clamps for my 06 KX250! WhistlingWhistlingWhistling
1/11/2016 12:57pm
@ge217
What, if any, changes were you able to feel doing that conversion? Does the shroud/frame area ever cause problems with pants, knee guards, braces or boots? What about the subframe, seat, gas tank combo? Does it change the sitting angle or grip (flatter, thinner, etc)? I've been looking at doing that conversion for a while but not until I have nothing else left to do.
ge217
Vero Beach, FL US
1/19/2016 9:41am
@ge217 What, if any, changes were you able to feel doing that conversion? Does the shroud/frame area ever cause problems with pants, knee guards, braces or...
@ge217
ge217
Vero Beach, FL US
1/20/2016 6:37am
The engine mounts would need altering yeah ?
Why would the engine mounts need to be altered? It's a plastics conversion...
Dillon27
Minot, ND US
1/25/2016 9:45am
Still have the kit for sale? I'm interested for my 2001 kx250
smezmx
Kent,medway.... GB
1/25/2016 11:48am
Just in case you missed it.
Dillon27
Minot, ND US
1/25/2016 2:49pm
smezmx wrote:
Just in case you missed it. [img]https://p.vitalmx.com/photos/forums/2016/01/25/121262/s1200_image.jpg[/img]
Great looking conversion. I want to convert my 01 kx250 but I'm still unsure of all the parts I'll need. Any insight on that?
ge217
Vero Beach, FL US
1/25/2016 3:05pm
yes my 12-15 kit is still for sale. As far as mounting it to a 2001 I am not sure on what that will take since the frame is different than the 03-07's.
Post a reply to: 2014 Kx 250 Two Stroke Plastic Conversion
