Canton, GA
1/18/2018 1:26pm
Just picked one up. As I was going through the bike I found this. The area lines up with the head of the bottom shock bolt so I could see if the bolt worked loose it could cause this to happen. That said it almost looks like it was put there on purpose for the fact that the cut is smooth and tapered somewhat towards the top and bottom of the link.
I'm ordering the new part today. Never seen this before.
Any opinions?
Any opinions?
But I've never seen a linkage with that kind of damage, good for you that you found it before you got hurt.
The valves are measuring in spec but on the tight side of the scale. I'm getting .10 kinda loose on the intake and .13 fairly snug on the exhaust. Any reason for concern there?
Post a reply to: 2016 KTM 350 sxf linkage problem/question
