Hauppauge, NY
After assembling the transmission before installing a new output sprocket, the output shaft was free to spin.
Once I tighten the nut on the output sprocket. I now have a slight bind, when rotating the sprocket, I can rotate the sprocket by hand but feel a tight spot. I have to push a lot harder to rotate it.
I need advise if I need to take it a part or not and what could be the problem.
Thank for your help.
I have not yet been able to try anything.
I did install a new counter shaft bearing.
If tap on the shaft does not do it, Will if have to come apart or can i use it the way it is?
Post a reply to: 1979 RM125 need advice on Transmission Bind
