Black River Falls, WI
5/17/2013 3:22am
Hey everyone,
Recently bought an '83 YZ125 that had no top end power. Found that the power valve was not functioning & badly worn in several places. Anyone know where I could find one? Need the valve & the linkage but the governor is fine.
Appreciate any help.
I sent him an email prior to posting this but haven't heard back from him. Will call.
330-821-8777 and ask for Shawn.
Thanks!
And be sure to get the two little dots lined up on the PV. There is one on the valve end, and the other is on the linkage plate that attaches to the valve. It will run in either position, but if the marks are off, the valve is 180 degrees out of phase.
The valve is then operating exactly opposite of the way it is designed to. Top end power will be non existent. Be sure to Loctite the center allen screw that holds the valve halves together.
http://www.ebay.com/itm/NEW-NOS-Genuine-Yamaha-Cylinder-Valve-1-YZ125-3…
Appreciate the tip on the dots... I did not know about that.
LOCTITE!!!!! The previous owner did not use it on that allen screw which is what ruined the power valve I have now. The threads for that screw are stripped out & the hole is out of round. The holes for the alignment pins are also egged out.
Think I may follow your advice about just buying a new power valve & looking for the linkage used.
Thanks for your help!
Thanks for the help guys.
Yamaha Motor - 5X4-1131A-00-00
VALVE 1 $117.66 1
On Order Scheduled to Ship Friday MAY 10, 2013(due from manufacturer)
Ship Method FEDXGR
Yamaha Motor - 5X5-11937-00-00
BOSS,COLLAR $7.53 1
Ship Method FEDXGR
Yamaha Motor - 93104-16074-00
OIL SEAL,SO-TYPE $9.35 1
Ship Method FEDXGR
Yamaha Motor - 932Yamaha Motor - 09192-00
O-RING $4.02 1
Ship Method FEDXGR
Yamaha Motor - 932Yamaha Motor - 270A8-00
O-RING $4.97 1
Ship Method FEDXGR
Need a seat for the '81 too if you happen to have one... or parts of one?
Give me a call.
Thanks!
Thanks for the help!!
Post a reply to: 1983 YZ125 power valve
