Price, UT
dirt rider777
3/8/2019 5:35am
3/8/2019 5:35am
Bike will only run on full choke and even then it backfires and shoots flames out and I can't give it the throttle or it dies. I have installed a JD jetting kit and cleaned the carb and have also checked the timing chain and valves and they are all in spec. I am stumpes anybody have any other suggestions to try?
You stated you cleaned the carb. How did you do that?
Did you pull all the jets and clean each? If not, do so.
Compressed air through all the passages in both directions if possible.
Double check all air boot clamps.
Post a reply to: 05 CRF250R issues
