Sounds like a dirty plug connection. I would suggest doing an OHMs test on the coil, both primary and secondary.
I would also check the connections to the ECU.
I would also check for a possible fuel flow issue and or float being set too low.
I would also check the connections...
Post a reply to: 08 kx250f cutting out mid an up
