Ravenna, MI
ktm-5
9/26/2017 12:52pm
9/26/2017 12:52pm
Getting ready to install my vortex and was wondering what about the switch on the handlebars? Do I put it on switch 1 or 2? Does it matter? Also the paper I have says to change tps end points to same as 350/450sxf_16 & update acceleration settings.....any ideas on what that means?
I have deleted the potentiometer and make it always be on aggressive map with solid resistor. No i have the vortex ecu so how the map switch (located at bar) is going to respond, same way 1 is number one map and 2 is what you have selected at the vortex ecu (like 8 based on standart map)?
Then IF i want to changes the maps i remove the seat end change the map with screwdriver from the Vortex ECU. So can anyone help me with this, is it going to work? My bike is "under construction" (some tranny issues 3thrd time..) for now so i cant really test it
Here in Finland when you need some technical help you dont get it......
I have one on my 2016 Sxf 270 and that is how I make any changes.
Post a reply to: 16 250sxf vortex and handle bar switch
