Howard City, MI
kkroll20
8/24/2017 8:28am
8/24/2017 8:28am
I'm having issues trying to dial my forks. I had them working decent but they were really harsh in the smaller chop so I tried a few different settings on the showa app. After I changed it up I can't get it to turn. Coming into a corner there's almost zero front tire traction, even after going back to stock setting and my old setting with pressures and the clickers. I'm 170lbs running 105mm sag 174psi inner 14psi outer and 189psi balance. Any ideas what could've happened?
I got mine on my 15 kx450f revalved, and a tip i was given was to run equal pressure in the innner and balance chambers, and zero in the outter. This makes it feel most like a spring fork, and you just adjust clickers from there. i ran 190/0/190, and just added compression and rebound and found it felt pretty good.
Post a reply to: 16 kx450f fork help
