Melrose, MA
Mdesmond
2/2/2018 9:37am
2/2/2018 9:37am
2/5/2018 6:06pm
I have a 1988 RM250 that I am starting to rebuild. I have the suspension out to a local shop for rebuild and they called today to tell me the rear shock body has some of the anodizing worn off the inside of the shock body. They recommend seeing if I can find another shock body to use.
Does anyone have a suggestion as to how I can determine what years and models used this same KYB shock body? The Suzuki OEM fiche doesn't list a specific PN for the body. My guess is that the same shock body was used for several years and models. I am trying to make sure I can search as widely as possible for a replacement.
The other options would be to:
1. Rebuild the shock and use it as is.
2. Not sure if the anodizing can be removed and re-done?
I'm guessing this is not a unique problem for older bikes and would appreciate any suggestions/help.
Part numbers for the 1989 model through 1992 model all look like 62100-28C**-163, with only the asterisks changing. From what I understand about Suzuki's part numbers superseding, I think any of those models would interchange. Putting any of those shocks on your bike, however, might be a different story. For what it's worth, the exploded drawings look the same.
My suggestion would be to re-anodize the shock body at a reputable finishings vendor and reuse the existing piece.
Look up hard anodizing service or roll the dice on a used shock off ebay, etc.
If you want to try a different year, look on eBay auctions, current and complete and look for differences. You might not rule some in, but you can surely rule some out.
If that does not work I may look at the anodizing option or more likely rebuild what I have. The shop told me that once the shock starts to wear off the anodizing it will continue to do so and that this can effect the damping. That's the main concern.
Post a reply to: 1988 RM 250 Rear Shock Question
