2 Stroke Compression Ratio/Tuning Help
FahQ
NJ US
12/4/2017 7:16am
98 Octane euro (RON) is equivalent to US R+M/2 93, and is approximately 90 MON.
Not to many tuners are going to recommend a squish that tight with that fuel.
I would add a gallon of leaded race fuel to 4 gals of that to be safe. Even 100LL avgas would help!
riv187
Lakeland, FL US
12/4/2017 7:39am
JoeKTM ,I have a 18 TC125 so I'm watching his closely. I run straight 110 race gas in my stock bike. Been leaning low end ,first pilot,then cutting slide,,as it will load up on the 9 plug if left to idle 10 seconds. Did cutting your deck clean up the jetting? Did opening the combustion chamber help and in what way? These where exactly my next moves on mine to improve the rideability
brentry
Rockford, IL US
12/4/2017 8:46am
Loosen sq and put it at 14.5 comp
And run pump if you want. Thats. Assuming Stock pipe. As the pipe sets the cylinder pressure. Taking orings out. Means its not happy.
Little to aggressive
endurox
Garden City, ID US
12/5/2017 8:13am
Besides the insert, did the head insert holder also get milled ?
Post a reply to: 2 Stroke Compression Ratio/Tuning Help
