- Pick trends
- Create a private league
- And more!
Crf It has amazing turn
All it takes is a little lower back (fc ,pc or ride links )
Had 09-10 CRF450r's that came with 20mm oem triple clamps that gave the bike sharper steering, but less stability at higher speeds. 2005-06 models owned with 24mm oem clamps gave the bike very good stability, but not good steering. Tried 22mm PC clamps on the 06 (to improve steering) that slightly helped turning giving it a little less stability. An 08 model owned came with 22mm oem clamps & seemed to be a happy medium.
Chassis geometry has a lot to do with the equation of the head steering angle (turning) & stability with the clamp set measurement allowing a little tune-ability. From my understanding Honda went back to similiar specs on the 17-19 chassis geometry as the 08 model that came with 22mm oem triple clamps.
Based on what I've experienced with 250 2t's or 450's using different offset clamps, the 20mm ones will give the bike less stability with slightly better steering.
Here is a good article I read a few yrs. back on triple clamp offsets.
https://motocrossactionmag.com/ten-things-about-triple-clamp-offset/
"In the end, riders find that clamps with reduced offset steer better, because altogether it gives the bike a MORE STABLE FEEL—but with easier steering and with a front tire that stays more planted."
Ok. Just trying to help you out. The manufacturer engineers generally know whats best as oem specs from the factory. I'd think if the 20mm was a better option the 17-19 models would have come with them off the showroom floor. They do a lot of testing before the models are released, but that's not to say the 20mm ones might work better due to personal preference on how the bike feels. Good luck on your quest...
Post a reply to: 20 mm offset on 17-18 or 19 crf 450
