2003 rm125 rear wheel play
.jp
Fairfax, VA US
Have a rm125 i recently went through top to bottom to lube and inspect, didn’t notice any issues. Not sure if it was there to begin with but when it’s on the stand and I grab the rear wheel there is noticeable play up and down that seems to be from either the upper or lower shock. Is this normal or should I look into replacing the upper and lower shock bearings. Shock was just at factory Connection for a rebuild and they said the bearings were good.
Matt Fisher
Visalia, CA US
1117th
11/5/2017 5:37pm
Replace whatever is worn. Easy way to tell is to put a finger on the bearing surface and move the wheel up and down. If there's play you'll feel it.
Benton, LA US
11/5/2017 5:37pm
There should not be any play in any direction on the shock. I would be suspect of the linkage bearings.
.jp
Fairfax, VA US
11/5/2017 5:41pm
Thanks for the replies. I’ve ordered new bearings already as a precaution. Was honestly hoping to not tear it back down again so soon but it is what it is. Thanks again.
Bruce372
11/6/2017 7:19am
Unless it's excessive, I wouldn't worry. All showa shocks have a small amount of play in the top bearing. When multiply that by the linkage ratio, it's enough to feel when lifting the wheel
Post a reply to: 2003 rm125 rear wheel play
