Newport Beach, CA
I have an 05' and I recently have 09' 450 suspension on it. My question is which axle so I use on the front wheel? I believe I read the 05 2 stroke axle won't work as it will be to long. I want to make sure which year I use so I can order it. Any help will be appreciated
Sorry i cant help more than that.
If you are just doing the forks and not the triple clamps, then I'm not so sure about the axle. Seems like the people that did that had to cut the wheel spacers in order the get the front wheel centered? I'm not positive about that part though.
I'll order the 09' axle, I'm just not sure if the axle I have is the 05' or from the 09'
Thanks I appreciate it
Post a reply to: 2005 yz250 sss conversion help
