2009 yz125 bottom end ! Need help
luis97
Ridgewood, NY US
9/28/2017 5:05am
Hey, I was wondering if someone could help me on an estimate. How much would it cost to rebuild a 2009 yz125 bottom end. Also what places do you guys know that would do this work. Thank you guys very much.
slipdog
Nor Cal, CA US
9/28/2017 7:41am
I've been doing a lot of reading here at Vital and have learned that you can rebuild a 2 stroke bottom end for $162.14. If you add in the $26.44 for a top end kit you can have an all new engine in her for less than $200
slipdog
Nor Cal, CA US
9/28/2017 7:42am
Ok, I may be full of crap this morning. You should call a local mechanic to get a detailed quote.
NJKawi913
Somerset, NJ US
9/28/2017 8:58am
luis97 wrote:
Hey, I was wondering if someone could help me on an estimate. How much would it cost to rebuild a 2009 yz125 bottom end. Also what...
it all depends on what you are having done. rebuild the crank, replace it with a new crank, tranmission work, etc... it could be anywhere from $500-$1500 dollards depedning on what they find when the split the cases.
lumpy790
York, SC US
9/29/2017 7:11am
Depends on what parts you need and guessing $300-$400 for labor
Acidreamer
Mansfield, OH US
9/29/2017 7:19am
Id set aside $1000 to be safe. A connecting rod can be over $300 if you buy high end like a carillo rod. Some builders only use OEM parts which is a lot more expensive than aftermarket stuff. Millennium tech and ken oconnor are places i know that do it off the top of my head. Call them for something accurate. It really depends on the parts you use. Labor is a few hundred at the most.
9/6/2023 9:21am
After 5 months my 05 crank is replaced. Labor charge 633.00 hv prices really gone up that much ? My estimate was 500 then 100 is added to remove the engine. I was told 500 for dropping the whole bike off . Removing engine was included.  This is a new buisness.  Is that the going rate now ? Plz respond
walent215
Ridgecrest, CA US
9/6/2023 12:03pm
NJKawi913 wrote:
it all depends on what you are having done. rebuild the crank, replace it with a new crank, tranmission work, etc... it could be anywhere from...
$1500 + for sure
even if the top end is “ fine “ I’m putting a new piston and ring in if I rebuilt the bottom end so in my eyes it’s a complete rebuild and not just bottom end …. And as mentioned above you never know what you’re going to find until you get it all apart .
MxAddic
NY US
9/6/2023 3:06pm Edited Date/Time 9/6/2023 3:08pm
After 5 months my 05 crank is replaced. Labor charge 633.00 hv prices really gone up that much ? My estimate was 500 then 100 is...
Sounds about right.
40acres
Tomball, TX US
9/6/2023 4:09pm
Jesus Christ, I hope the OP has this sorted after 6 years. Come on guys, how the hell do you even find a post this old?
Post a reply to: 2009 yz125 bottom end ! Need help
