2012 KX250F crankshaft bearing C-rating
Wouterb
NL
Hi,
I'm rebuilding the engine from my 2012 KX250F and can not find anywhere what the C-ratings for the crankshaft bearings should be.
Anybody know what clearance should be used? C2, C, C3 or C4?
I can get a hold of any bearing (cheap also) and do'n want to pay too much for aftermarket or OEM :-)
Please let me know if you have any info/insight.
Thanks!
Best regards,
Wouter
kb228
Mansfield, OH US
5/25/2018 6:27am
Unless its stamped on the old bearings you probably wont find out. All that is calculated by the engineers. All that rating is is a load rating.
Tracktor
The RTF/Amboy, WA US
5/25/2018 10:50am
Whatever you fo don’t go too tight. I tried that thinking the tighter tolerances meant better bearing on one of our 85’s snd it started seizing within a few hours. Lesson learned. Most crank bearings seem to call for a C3 rating IIRC...
Post a reply to: 2012 KX250F crankshaft bearing C-rating
