2013 yz250 suspension on 2003 yz250
jmarelt
Massillon, OH US
Edited Date/Time 2/20/2019 4:30pm
Alright, I have looked to see if I could find anything that relates to this particular swap but I can’t seem to find anything. I am looking to swap to SSS suspension on my 2003 YZ250 and I know that 2006-2008 yz450f suspension will boot right up to my bike with the 450’s triple clamp. However, I have been offered a set of 2013 yz250 suspension and would like to know if anyone has any insight if it will fit. I know I would need 48mm triple clamps and the sale would include the clamps from the ‘13 yz250 so that may take care of that issue(?).
I have looked for spec sheets but can’t seem to find anything. Does anyone know if this would work one way or another?
Thanks!!
jmarelt
Massillon, OH US
2/14/2019 7:12pm
You will need the clamps, brake caliper, wheel spacers, front plate and fender
You’re positive about this? Because I figured brake caliper, spacers, and number plate would need replaced too.
2/14/2019 10:00pm
Isn't that what I said
jmarelt
Massillon, OH US
2/15/2019 3:31am Edited Date/Time 2/15/2019 3:32am
Well I was not able to find anything online showing that it worked. You’re the only person to say anything about it. So, before I spend an exuberant amount of money, I am going to ask for a double confirmation. Have you done this swap yourself?
speed_racer
Aiea, HI US
2007th
2/15/2019 7:39am
This is my 2003 with 2006 Sunline clamps and 2006 450 forks. The picture shows 2006 clamps work with the steel frame.
2/15/2019 11:11am
jmarelt wrote:
Well I was not able to find anything online showing that it worked. You’re the only person to say anything about it. So, before I spend...
I've done multiple front end swaps on steel frame yz250s. The other thing you will need to do is weld a tab onto the existing turn stopper on the frame. This makes it larger and the clamp stopper will engage it. Pretty easy. One I did I put 2012 yz250f forks on and it didn't need it.
Wycked31
West Palm Beach, FL US
2/15/2019 12:03pm
This is my 2003 with 2006 Sunline clamps and 2006 450 forks. The picture shows 2006 clamps work with the steel frame. [img]https://p.vitalmx.com/photos/forums/2019/02/15/325555/s1200_20160114_190329.jpg[/img] [img]https://p.vitalmx.com/photos/forums/2019/02/15/325556/s1200_20160119_204341.jpg[/img] [img]https://p.vitalmx.com/photos/forums/2019/02/15/325557/s1200_20160114_190329.jpg[/img]
Did you have to change the steering stem on the 06 clamp to fit in the steel frame? I have a set of Ride Engeering clamps from a 09 frame but the steering stem is to short for the steel 03 frame
mattyhamz2
So Cal, CA US
767th
2/15/2019 12:11pm
Wycked31 wrote:
Did you have to change the steering stem on the 06 clamp to fit in the steel frame? I have a set of Ride Engeering clamps...
Steering stem will need to be swapped
2/15/2019 12:23pm
Yes forgot swap stems. 10 ton press should do.
Wycked31
2/15/2019 1:13pm
Thanks
SBD
San Diego, CA US
2/15/2019 1:48pm
Please keep use posted on this swap. I am planning to do the same thing soon !
2/15/2019 8:46pm
Super easy. Also another cool mod is use a 06 or newer shock body with your 16mm shaft. It will fit perfectly in the frame
cwtoyota
Tacoma, WA US
2/20/2019 12:03pm
I posted some detailed info and photos in the thread below. Give it a look:
https://www.vitalmx.com/forums/Race-Shop,42/2003-yz250-SSS-swap-help,13…
smoke
Athens, OH US
2/20/2019 4:27pm Edited Date/Time 2/20/2019 4:30pm
Get 04 triple clamps that way the stops will match up without hassle. I put 05's (same diameter)on my 2000. The only other thing I needed was 05 brake line and the metal bracket that bends the brake line around the forks sense they have a different design.
The stem on 04 and 00 are same and I suspect yours is same as mine
Post a reply to: 2013 yz250 suspension on 2003 yz250
