2016 to 2017 KTM Four Stroke Fork & Shock Changes
SPYGUY
725th
Thinking of swapping out my 4CS forks for AER's and am trying to get an understanding of the changes that were made between the 2016 and 2017 model KTM four strokes.
Is it true that the AER forks are slightly longer than the 4CS forks? If so, were there any changes made to the shock to compensate for the longer forks? Actually, now that I mention it, I know that the 2016 had 247mm length shock springs while the 2018's came with 260mm length spring. So does that mean that the shock was actually longer or were there changes to the linkage pullrod or something?
Thanks to anyone that can help me get straightened out!
aees
10/24/2018 12:48pm
No changes in geometry to compensate for the longer AER fork, or changes to shock. However, just because the fork is longer does not mean it is reflected into riding much higher.
My CV fork is shorter then my AER, but the ride height is same if i run them on the second line so to say.
CarlinoJoeVideo
Portland/Los Angeles, CA US
2339th
10/24/2018 6:29pm
The 18 to 19 have a bigger difference on the fork height feel.
On my 16 I rode with the shorter forks at 1-2 lines up. If you put the AER on, try and 2-3 lines up on the 17.
I run 105 sag to give you an idea on the balance.
Post a reply to: 2016 to 2017 KTM Four Stroke Fork & Shock Changes
