fullysicmate fullysicmate
8/5/2017 1:24 AM
The manual says minimum air pressure recommended is 102psi, I tried this today and my fork height dropped about 2-3 inches. Has anyone else tried it at this pressure? I am wondering if this could be good for flat track racing...
rjg rjg
8/9/2017 8:16 PM
I have no real world experience with air forks, but you should be careful doing that. It may have sacked out because of a air chamber leak. Do they extend back to normal length if you pump them back up to 140?
8/9/2017 8:20 PM
rjg wrote:
I have no real world ...more
Yes they went back to full extension.
seth505 seth505
8/10/2017 6:46 AM
I think you read it wrong, it is a base setting of 10.2 Bar which is equal to 148 PSI.
Oops, I read your post wrong and see you tried the minimum haha. I'm not flat tracker but I think a stiffer setup with shortened forks might work nicer.
Paw Paw Paw Paw
8/10/2017 3:39 PM
It seems that with that low a pressure and that much fork compression, you will be in the wrong part of the fork stroke to have good dampening.
8/10/2017 4:01 PM
Paw Paw wrote:
It seems that with that ...more
Not too much required in flat track.
