IE
I folks as the title says I got a ktm with a e start problem it keeps blowing the main fuses every time I Push the e start button
I swapped over a lot of bits trying to fault find but no joy even disconnected the two yellow cables coming from the coil or and it didn’t blow the fuse but still won’t start put in a new wiring harness in and still no joy. I’m really at the end of the road now and so disheartened by it
Has anybody ever come across this fault before
Thanks
Peter
Thanks
Peter
I changed as many parts as possible from another 350 (2016) there a brand new loom gone into the bike.
the bike still blows the main fuse even if you try to bump start it
the condenser was changed and the stater was changed too
If not that, there must be a wire loose or water got in somewhere. Did this start after a wash/wet riding day.
You need to trace back what changed before this first happened and that can give you an idea where to look.
Post a reply to: 2017 ktm 350 e start problem
