2018 ktm 450sxf rear spring rate
jonboy688
China Grove, NC US
i bought a spring a while back for a 16 250sxf and it is listed as 252.51 n/mm, i never installed it and now i have a 2018 ktm 450sxf and cant find where the calculator was that i used for the 250sxf over a year ago
so long question short will this spring work ok for my 18 ktm 450sxf i am 190ish without gear and just a out of shape 35 year old midpack c rider
slipdog
Nor Cal, CA US
2/26/2019 10:27am
Those numbers don't make any sense. I would guess that that is lbs/in which would make it 4.5kg or basically 44n/mm.
That is softer than your stock spring and I wouldn't recommend going that way, but you can give it a try. I use 48n/mm for people 190lbs on a 450.
jonboy688
China Grove, NC US
2/26/2019 10:49am
part number i ordered from rockymountain was 131307011550
its weird and i think its a messed up listing when i go to my order history because it appears the part numbers have been superseded
jonboy688
China Grove, NC US
2/26/2019 10:56am
never mind i am retarded it is 51 n/mm
for some reason the listing has spring252 51n/mm
but when i look it up for a 2018 ktm 450sxf it is listed as spring 260 51n/mm
will a 51n/mm be to stiff? thanks for the help
t_david
HU
2/26/2019 11:33am
Right now I test some different spring rates, I ran 45n/mm with my sx-f 350, after I change for 450 and I thought for my weight (195lbs with gear) the 48n/mm will be the right based on KTM chart.
Finally no, the 48n/mm was definietly too stiff, I could not setup the sag either, I recommend to try firstly the 45n/mm spring.
slipdog
Nor Cal, CA US
2/26/2019 11:41am
I think so. I've used that for 210-215lbs a lot. It will be stiff with very little spring preload
The 252 is a weird number, 260 means the spring length
jonboy688
China Grove, NC US
2/26/2019 12:29pm
well dang, anyone need a good deal on a fatboy rear spring lol
aees
2/27/2019 12:47am
46nm would be optimal but 48 is ok.
jonboy688
China Grove, NC US
2/27/2019 4:46am
i ordered the 48 n/mm and will give it a try, thanks for the help guys
Post a reply to: 2018 ktm 450sxf rear spring rate
