Houston, TX
kwenske321
12/6/2018 9:20pm
12/6/2018 9:20pm
The bike has 4.2 hrs on it and has been running flawlessly. Went riding on Saturday and washed the bike Sunday evening. During wash I always plug the mufflers and air box to seal out moisture. Went into the garage tonight to install a clean air filter, install the seat etc... Upon starting the bike, it ran poorly for about 2-3 seconds before shutting off and has not fired since. Is this the kill switch moisture problem I have read about?? The bike turns over and there is a scent of fuel in the air leading me to believe I can eliminate the fuel system and battery from being the problem. Any help and guidance is appreciated. Oh and yes... I am pulling the clutch lever in.
If you follow the kill switch wires around and unwrap them if they are taped together you should be able to unplug it from a connection point.
Ran to truck and loosened kill switch bike started running,
It was a bad kill switch
Ordered a new one and been good since
Post a reply to: 2019 Honda crf450rwe WILL NOT START!
