danman danman
9/12/2019 4:32 PM
Any recommendations on a battery for this bike? It doesn’t hold a charge right now and even when it is charged, it sounds like it struggles to turn it over.
Paw Paw 271 Paw Paw 271
9/12/2019 4:37 PM
Look at the LI battery's on the market for your bike. There are several very good ones. WPS, Shori and Firepower plus others.
danman danman
9/12/2019 4:58 PM
Paw Paw 271 wrote:
Look at the LI battery's ...more
thanks! I know I've seen people talk about using a battery with more aH or CCA's. I just didn't know if anyone had done that to theirs. That is one area I really don't understand, electrical stuff. I usually mutter through with YouTube
9/12/2019 7:42 PM
It is not just CCA's. It also has to do with the batteries construction. You have a lead acid battery and the ones I have suggested are not made like those. Your current battery can have a plate inside come loose due to vibrations and the hit of jump landings and die easy. Most OEM batteries are low dollar units as well. The batteries I have suggested will last a lot longer than the oem or even after market led acid batteries. It will be money well spent. They will be as much as 3 lbs lighter also.
CarlinoJoeVideo CarlinoJoeVideo
9/12/2019 9:25 PM
Firepower battery from RockyMountain AtVMC is really good bang for your buck.
danman danman
9/13/2019 6:11 AM
I went with the Firepower from RMATVMC
Info was much appreciated, especially the info from Paw. I never thought about the abuse part and the battery coming apart inside.
Motohead279 Motohead279
9/16/2019 10:41 PM
My 15.5 250 Factory Edition always struggled to start with the stock battery. With the WPS it cranks right up.
