- Pick trends
- Create a private league
- And more!
Used 22mm offset Neken clamps and improved a lot in high speed whoops and deep sand. 108 / 110 mm sag, forks down in the clamps, 13/48 gearing (allows to use the wheel further back)
Overall is not a good bike for sand tracks based in my experience
Anything else planned for your CRF? Those bikes respond well to a few simple changes like a Vortex ignition and a bit more compression. Personally, I don't like the aftermarket option of high comp pistons, so I deck the cylinder via my local shop Q&E or even running a thinner base gasket (as it's reversible to see if that's the proper direction to go)...
Post a reply to: 22mm clamps on 15/16 crf450
