Yuma, CO
So ive done a lot of research and everything ive ever heard about people putting air striker carbs on Honda 125s is all positive. I finally broke down and got one off of ebay (came off of a 2000 KX250). I'm wondering if any other vital members have done this and what I can expect when I get the carb. If you have done this what did you experience when jetting it for the 125? Does anyone have a rough idea of what I should start with? I know that I can and probably will end up just "plugging and playing" with it to get it right but if someone on here has done it and could point me in the right direction to start out I would appreciate any feedback.
The bike it is going on is a 2005 CR125 with a Millennium Tech 144 kit and I'm at 3,500 ft of elevation.
I'm back to 4th clip again. Ideally a 3.5 clip would be the best for me
The jetting specs that are listed above are for a pwk with a #7 slide.
Thanks for the replies.
CCL needle--https://www.jetsrus.com/individual_parts/017_464_su.html
#7 slide--https://www.jetsrus.com/individual_parts/018_522_su.html
I have alway used https://www.jetsrus.com/index.html without an issue.
Digger you had mentioned that the throttle cable is an easy fix? I'm a very competent mechanic and my dad is a welder so there isn't much I cant do. Do I just need to take my dremel and whack the top curved piece off of the KX's throttle cable guide?
I went ahead and got the 6.5 slide with the CCL needle. Ordered from jetsrus.com and had the slide and needle within a few days, would definitely purchase from them again! The main jet that I have in right now is a 182.
This bike does have cutouts in the air box so it gets a little bit more air than normal so I went ahead and put the needle in the 3rd clip. It runs pretty dang good! It is just a tad rich (cant really feel it but it does have a little splooge coming out of the silencer). If it was late spring/summer time here I would move the needle but it is going to start cooling off here pretty soon so I will just leave it in the 3rd clip and it should be about perfect here in 2-3 weeks. As for the TPS, the sensors didn't swap across like I thought they maybe would so after consulting with Kawasaki-rider I just left it unplugged and it doesn't seem to mess with the bike at all. As for the throttle cable hook-up that was a bit of an engineering project. The kawi guide seemed to be fixed into the carb cap and there was no way to remove it. After a little dremel action I had that out and then the hole that it went through was too big for me to thread the other guide into. So after some brainstorming I ended up using the nut off the old carbs guide and putting it on the underside of the new cap and then filing down the top just a bit so the old guide would grab all of the threads in the nut on the other side and then I used red lock-tite to make sure it wasn't going to loosen up on me. Got it all hooked up and it worked perfectly. (If that didn't make much sense and you would like to see what I did let me know and I will take some pictures)
Now that its all said and done I am drinking the Kool-Aid that this is a must do mod. It is cheap and fairly simple and the results are night and day! The power is smooth as butter and no hickups anywhere. Thank you Digger and Kawi-rider for the helpful tips and advice!
Oh BTW for those who may give a fuck...
Proper Throttle cable? Do not order it from Lectron. Both versions they provide are way too short.
For the 36mm Lectron "Shorty", contact Motion Pro. 05'-07' Honda CR125 needs THROTTLE: 07-1366 HL + 7" **ELIMINATE INLINE ADJUSTER**
Post a reply to: CR125 Air Striker Carb Swap
