Saratoga Springs, NY
12/16/2018 12:54pm
1988 Rm 250 full rebuild about 4 years ago, 8-10 hrs run time, was running good, 1 ring piston, figured I would pull it down to inspect. Cylinder replated & piston matched by Powersealusa. I use Evans waterless coolant, it is clear With a blue tint when new, when I drained it it was darker & had a 2 stroke burned oil smell, like exhaust gases were being pushed into the coolant system...it did not overheat & I did not find coolant in the pipe....the underside looks brand new, no oil stains. The sidewalls of the piston are near perfect. all opinion are encouraged & welcome...thanks...
I would have the piston to cylinder fit checked as well as the ring end gap.
I too suspect a leaking head gasket.
It may very well have a head leak. My point was merely that it in your case, it is impossible to say definitively that it has a leak or is "compressing water" based on looking at the piston alone.
You can use a granite or marble counter top or window pane to check the surfaces for being flat although it's pretty hard to check the cylinder on a window pane. Just clan the sealing surfaces then color them with black felt pen then put a piece of 32o sand paper on the counter or window then place the cylinder or head on it then rotate it a few times then look at the colored surface. If it is not flat, there will be areas where a lot of the color remains. If the surface is not too warped you can surface it this way also but yu will likely need coarser paper like 220 and some water or wd40 on it. You can also put water on the 320 for the initial flatness check.
Ok, I for one would have the cylinder machined until it is flush with the cylinder. Shouldn't cost more than $40.00 and might take all of 10 minutes for a machine shop to do. You could also have them cut around .001" off the top of the liner if you wanted.
i also would not use evans coolant. regular 50/50 coolant is fine, and if you add 1.5 times the recommended amount of dei radiator relief to it, it will work even better.
Post a reply to: Can I get a piston read?
