Went to change the water pump seals on my 08 YZ125 & I noticed the govner dowel was broken in 3 pieces. Then checked the power valve and on the left hand valve, the dowel that's pressed in had come out & was laying in the bottom. Govner pin £0.22, valve £168
Are these common problems?
https://thumpertalk.com/forums/topic/1053251-yz125-power-valve-pins-using-roll-pins/
Post a reply to: Common problem on a YZ125?
