Saratoga Springs, NY
8/14/2017 3:42pm
Picked up some eBay engine cases for my 96 cr 250.. I need the left side case. Upon further inspection I see what appears to be 2 cracks where the transmission bearing installs, right behind the clutch actuating arm. These cases are no longer availible new or I would have bought new ones...any opinions....can the case be tested to see if they are actual cracks or casting marks? Can they be welded correctly? Send them back & keep looking? Thanks for input,both cracks or flaws around 11 & 1 o'clock.
[img]https://p.vitalmx.com/photos/forums/2017/07/27/206691/s1200_image.jpg[/
You could bubble test with dish soap and compressed air. Mix up some soap and water, then apply to the area and then blow air at it while looking at the other side to see if the crack passes all the way through. If you see soap/water coming through you might want to talk to a qualified welder.
Post a reply to: Crack or casting marks?
