Caldwell, ID
2StrokeWanting4StrokeOwning
1/18/2018 8:25pm
1/18/2018 8:25pm
1/19/2018 8:12pm
Hey guys, I have researched this on the internet suite a bit and it seems to be a bit more how your bike is set up.
I was wondering if someone could tell me a recommended carb setup for.
2006 Honda crf250r.
Stock motor, exhaust, and everything.
My elevation is anywhere from 2,700ft to 4,000 ft.
And ELIMINATE THAT CRAPPY WFO BOG!
Any help is much appreciated.
2006 Honda crf250r.
I don’t think you can consult Tamir on this one, being a Honda and all. Here’s to keeping a thread in a perpetual loop. Help is much appreciated!
That will fix your problem.
Adjust the fuel screw.
Check the accelerator pump timming and direction of spray. It should not hit the slide.
2. New plug, fresh gas and clean air filter
3. Carb clamps tight?
4. ProCircuit jetting https://www.procircuit.com/jettingspecs2.htm#2006.
A more pricier option is the JD jetting kit. Works great!
None of above will work with a dirty carb or cracked Orings.
Post a reply to: Dreaded Honda Bog
