Dang It Dang It
1/22/2018 11:36 PM
I have a problem starting my carbureter equipped Honda CRF 250 2008. Compression, valve clearances good. Thorough cleaning of carb and jets. It will start easily with a squirt of starter fluid and it will start easily if I lean the bike on it's side and let the fuel flood from one of the overflows. I had exactly the same issue with a 2001 CR 250 two stoke. Any ideas?
TrailDigger TrailDigger
1/23/2018 2:11 AM
Carb isn’t set right. Try messing with the air screw and make sure your float height is set correctly.
Acidreamer Acidreamer
1/23/2018 2:57 AM
Is your jetting too lean? Sounds like its not getting gas. Check float height/pilot jets
2009 Kawasaki KX450F
2009 Kawasaki KX250F
2002 Suzuki GSXR 600
Paw Paw 271 Paw Paw 271
1/23/2018 5:57 AM
Fuel screw set too lean and pilot jet size may be too small. Also check float height.
Dang It Dang It
1/23/2018 4:43 PM
Thanks everyone! I will try the fuel screw and if that doesn't work I will try a larger pilot jet.
