High PSI cap
I just bought some new rad. hoses from CV4, and in a lot of the reviews I was reading on the product people were claiming the cv4 hose kit plus a high pressure radiator cap were dropping their operating temperature by 10° plus.
Are high psi caps the bees knees or are they just a “performance part”? Maybe they’re best for hot weather riding?
BR8ES
Bennett, CO US
9/21/2018 6:10am
Don't the KTMs come with a 1.8? Just higher boil over pretty much. Not sure how the cap reduces temps though.
DB97
Orlando, FL US
9/21/2018 6:10am
They raise the boiling point of the coolant due to being a higher pressure. You can also use Evans waterless coolant instead it has the same effect basically.
harescrambled
Warren, OH US
1992nd
9/21/2018 10:19am
DB97 wrote:
They raise the boiling point of the coolant due to being a higher pressure. You can also use Evans waterless coolant instead it has the same...
Evans waterless coolant doesn't boil until it hits 375F. It also doesn't build pressure like water bearing coolants.
Flipsid33
Canyon Country, CA US
9/21/2018 10:35am
Makes your hoses easier to puncture. Would upgrade to silicone hoses.
Post a reply to: High PSI cap
