Honda Front End
dylanv21
Fresno, CA US
I bought an 04 CR125, and I have a set of 08 CRF250 forks/triple clamps I was going to put on the 125. I know the clamps will bolt and what not, but I wanted to make sure the front wheel/front brake caliper will also go on no problem if I use the original wheel and caliper. I believe it will, but I just wanted to make sure!
FGR01
AZ US
1327th
12/3/2017 5:05pm
Pretty sure you can just slide the CRF250 forks into your 125 clamps. Any reason you want to use the CRF250 clamps?
Paw Paw 271
Benton, LA US
12/3/2017 5:05pm
I would check the axle size as it may be different.
dylanv21
Fresno, CA US
12/3/2017 5:13pm
No particular reason, figured it would just be easier since I know they work with the 08 forks.
dylanv21
Fresno, CA US
12/3/2017 5:13pm
I believe the hubs are the same, I will have to double check! Thanks!
Post a reply to: Honda Front End
