Honda gas in the oil
kb228
Mansfield, OH US
11/27/2018 11:20am
I thought this was a problem with bad injectors sticking open
revitout
NZ
11/27/2018 11:24am
I've been trying to work out when the fuel is making its way in there. I think its not from sitting after riding cause I drain the oil and get nothing more over the next week or so.
MotoCoUSA
Colorado Springs, CO US
11/27/2018 11:51am
well that's great. Hopefully what I'm trying will work, if not ill just try a new fuel injector. Not sure what else it could be.
revitout
NZ
11/27/2018 11:58am
Cool let us know what you try , I'm keen to sort this out. See you're from CO , I used to live in Breckenridge , mean part of the world over there!
barnett468
Wildomar, CA US
11/27/2018 5:50pm
revitout wrote:
Its not cold where I've been riding so it can't be that. I need to try relieving pressure in the fuel line after riding to see...
Its not cold where I've been riding so it can't be that. I need to try relieving pressure in the fuel line after riding to see if that helps. Has anyone tried that?
If you have enough room in the line you could but a T in the line before and after the injector pump with an on off valve. Keep the valve closed while running then open it when you stop which will let the pressure out back into the line before the pump.
dtl210
Post Falls, ID US
11/28/2018 11:36am
Gas in the oil is common on fuel injected bikes used for snowbikes. Most of the time caused by bikes running rich due to being to cold.
Install a TTO temp sensor from trail tech right out of the head. I bet you'll be surprised how cool this bikes run in moderate weather. A thermostat will help keep it above 170 degrees and you bike will run better.
Might not be your issue, but worth looking into!
Post a reply to: Honda gas in the oil
