Husky TX300 Clutch not engaging all the way
Maybe this is normal, not sure. When the bike is off and in gear, even with the clutch pulled, it won't roll. If the bike is running the clutch engages enough to keep it from stalling. Is it possible to adjust the engagement? My previous bike had a rekluse so i didn't notice if it did a similar thing
DTR830
Mountain Top, PA US
1105th
11/14/2018 7:51pm
oem levers or arc?
Paw Paw 271
Benton, LA US
11/15/2018 9:16am
Bikes don't roll easy with the clutch pulled in and in gear. It is the nature of the gear reduction system in the trans. Remember that you have a very low overall gearing due to the engines high rpm limits and the speeds derived from said gearing. It is a big mechanical advantage and thus it will not roll easy that way. That is normal.
11/15/2018 9:17am
Bikes don't roll easy with the clutch pulled in and in gear. It is the nature of the gear reduction system in the trans. Remember that...
Good to know. Thanks
sandman768
Saratoga Springs, NY US
11/16/2018 6:10pm
Could have air in system, if it creeps when you put it in gear, with clutch pulled in...may need to bleed line...
Post a reply to: Husky TX300 Clutch not engaging all the way
