Ryan.Amoils Ryan.Amoils
9/19/2017 6:10 AM
Anyone know what is causing this and what needs to be fixed. On KTM 250 SX-F?
Acidreamer Acidreamer
9/19/2017 8:10 AM
2 things or a combination of both.
The gasket neees replaced.
You didnt put any or enough yamabond or similar on the lobes of the gasket.
I usually put a generous amount of yamabond on when i do my kx. If i dont it always leaks even with a fresh gasket.
2009 Kawasaki KX450F
2009 Kawasaki KX250F
2002 Suzuki GSXR 600
shaunbruce827 shaunbruce827
9/19/2017 10:31 AM
My 2016 Husqvarna FC250 did this as well. It's common for the gasket to start leaking after having it on and off multiple times, or just old age. When I put in a new piston at 92 hours, I also installed a new valve cover gasket. Do not use any sort of sealant on the gasket, it will likely flake off and end up inside of your engine.
9/19/2017 11:20 AM
shaunbruce827 wrote:
My 2016 Husqvarna FC250 ...more
Every service manual says to put silicone sealant on the lobes.
ktm-5 ktm-5
9/19/2017 5:30 PM
I too had this same issue on our 16 250sxf pretty much right from it being new, I put a light layer of hondabond on it and no more leak. Just make sure u don't use too much to where it will get in the motor. Also I only put it on the side of the lobes not around the whole thing
