elikoz elikoz
7/28/2017 11:22 PM
Hello dear friends smile
from this mxa race test
http://motocrossactionmag.com/mxa-race-test-2017-ktm-250sxf/
they recommend a 105mm sag and the stock one is 110mm
my questing is there really big change if i will change from 110 to 105? im 70kg without the clothes
and if i should change what will be the benefits?
much ty guys
ktm-5 ktm-5
7/29/2017 2:32 AM
The sag is very important and I always ask my suspension guy where to start and see how it rides. The beginning of this year I forgot to set the sag and when my son was riding our rough track the rear end was swapping back and forth and that was 10mm off. My son is a local A racer and I believe his is set at 100mm.
Best thing to do is try it, I would start at one setting say 100mm, ride it then try 105 and 110 and see what best fits u. I have found that the review's are a good starting point but always try a couple different also to find what best suits u.
aees aees
7/29/2017 2:40 AM
Span is 104-108mm, rider preference. You are pretty much target weight. So i would set it to 106mm and adjust front from there.
2016 recommended was 110, they changed it to 105 for 2017.
Since there are airforks on 17, you might get away with 110mm and more but not an optimal setup to soften front because of a too soft set rear.
elikoz elikoz
7/29/2017 3:32 AM
aees wrote:
Span is 104-108mm, rider ...more
so you sugggest ill try the 105 ? will be better then 110?
and how it will help me on truck?
CarlinoJoeVideo CarlinoJoeVideo
7/29/2017 4:38 AM
elikoz wrote:
so you sugggest ill try ...more
I have a 2016 and like 105-106 the best.
General idea, the lower number 100-106 will give you more front end feel but maybe less stability at high speed. Turn fast and sharp.
107-110 is better for sand tracks, getting weight off the front, more sitting low in the backend and better high speed stability.
Paw Paw Paw Paw
7/29/2017 9:06 AM
The sag figures only work if the bike is correctly sprung for your weight.
elikoz elikoz
7/30/2017 10:05 AM
more opinions?
mxb2 mxb2
7/30/2017 10:56 AM
Paw Paw wrote:
The sag figures only work ...more
Boom.
Harry Backmon Harry Backmon
8/9/2017 3:47 AM
elikoz wrote:
more opinions?
Get a cat.
Much ty
