- Pick trends
- Create a private league
- And more!
As I understand it the normal reading would be at about .5 volt dc at idle throttle setting, but if it were increased to
about .75 volt or even 1 volt it would make the fuel mix richer at idle and all the way up the rpm range until you have a full 5 volts.
At wide open throttle it would be 5 volt and it would reach this quicker ( lower in the rpm range) with the use of the increased voltage at idle.
I have used this as a base on Hondas.
Post a reply to: KTM tps setting
