Pass Christian, MS
Ive tried to search for this quite a bit now and I cant find out any information. I picked up a 2017 yz125 that im building. i know the psf1 came on the 13-14 kx450s. im just trying to get some info on if anyway has done this swap or not? i know a few parts would have to be changed. Just trying to get an idea of what im possibly getting into. any info would be great. main reason im wanting to do the swap is im building this bike to be as light as possible. sounds kinda dumb for a 125 but it think it would be fun.
I have a set I reworked for yz450f, pretty good result. Now we are retrofitting a set on an 06 kx250.
If kx or yz clamps are not compatible you would need new clamps. Enzo should have all the answeres you need as they are the ones helping outfitt star racing with their psf1's on their 250f's
There is a guy macz something that posts on here who is very knowledgeable on swaps.
Or maybey you could shim the upper clamp.
Tou would need a honda front wheel bolt. Unsure what breakes fit but i know suzuki and crf only needed diffrent adapter brackets.
wheels maybe only need custom wheel spacer.
Did the conversion on a ktm myself
Post a reply to: KYB SSS forks to KYB PSF1 swap
