elikoz elikoz
8/5/2017 11:19 AM
Hello guys i need your help please
i Purchased the ktm sxf 250 2017 it has 15 hours and its brand new
when i bought it and give a little of gas and go to high RPM when i stop the gas i hearing some backfires
the bike is not getting stopped or something neither when i pull the gas i dont get any back fires
just when i leave the gas at high rpm im hearing and getting some
im jsut wondering why its happens? i see other bikes like me new and they dont have it
much ty
Paw Paw Paw Paw
8/5/2017 1:47 PM
When you close the throttle, you are creating a very lean condition causing the backfire. The TPS may not be set correctly. The TPS will call for a much leaner condition when the throttle is closed very quickly as apposed to just rolling the throttle back. The TPS controls the fuel mixture in every rpm range and is the leanest at closed throttle.
elikoz elikoz
8/6/2017 2:02 AM
Is it effect the bike some how or losing power band some hiw? Or just ignore it? And why the tps is not correct i just got it brand new lol
How can i fix it
Much ty
Harry Backmon Harry Backmon
8/6/2017 3:47 AM
You gotta get your sag set correctly. That will stop the backfiring.
Much welcome
HenryA HenryA
8/6/2017 4:16 AM
elikoz wrote:
Is it effect the bike some ...more
Call your dealer then if it's brand new.
#1
KX125
Paw Paw Paw Paw
8/6/2017 7:27 AM
The dealer may be able to help.
One question first....
Has the exhaust pipe been off the bike? If so, the seal to the head from the pipe will need to be replaced. If it leaks the exhaust will become very lean and also cause this backfiring.
The dealer should be able to check the TPS as well.
elikoz elikoz
8/6/2017 7:40 AM
Paw Paw wrote:
The dealer may be able to ...more
it is effect the bike somehow? or i can jsut leave it like this?
and much ty for the seriously responds sir
8/6/2017 7:48 AM
Does it have the stock pipe?
CarlinoJoeVideo CarlinoJoeVideo
8/6/2017 8:53 AM
elikoz wrote:
it is effect the bike ...more
You can leave it. But if you want to get the best performance you can have it adjusted and fixed.
elikoz elikoz
8/6/2017 10:16 AM
yea bike has a stock pipe
Bruce372 Bruce372
8/6/2017 10:52 AM
If it's like the 450, just turn up the idle slightly and try that.
The tps setting on the new bikes are slightly different than the old ones.
8/6/2017 10:59 AM
...more
That's the one Where you gotta stick a potato in the muffler. It stops the back firing instantly.
Much ty
slipdog slipdog
8/6/2017 4:03 PM
...more
Harry Backmon wrote:
That's the one Where you ...more
He's not going to fall for your old potato in the tailpipe trick!
I-ty okuningi
elikoz elikoz
8/9/2017 7:38 AM
does anyone haver an idea?
8/9/2017 11:11 AM
elikoz wrote:
does anyone haver an idea? ...more
Tamir, you should ask this question in the moto section. You'll get a lot more responses.
Much ty
elikoz elikoz
8/14/2017 8:45 AM
any seriously thoughts?
