Boston, MA
I am destroying my plastic shock collar when I adjust preload. I have to adjust frequently as I will go from hard pack to sand tracks (104-110 sag)
I am using screwdriver/hammer, any tips on what to use instead or different technique?
Thanks for any help
Thanks for any help
https://www.chapmoto.com/ktm-shock-preload-spanner-wrench-u6951172?gcli…
XTrig makes the adjuster that you use a 8mm T handle and just spin it.
I’m at 110 3rd line for sand maybe I’ll leave sag at 110 and raise forks for hardpack.
I’m just amazed how big a difference I can feel with 5 mm sag makes a huge difference
They are out there, but if your threads are clean and the bike is off the ground, you should be able to move by twisting thr spring as others have mentioned
tool or x-trig?
thanks appreciate the generosity
But if you just need one to get by right now, it’s yours
Post a reply to: Ktm plastic shock collar /preload
